nas a todos
casanova
nas a todos
Mensaje por casanova »
soy novato en esto de los saab tengo un 9000 2.3 t aero del 94
si alguien fuera tan amable de poder las caracteristicas del coche, ya que el antiguo dueño no tenia el libro del coche, gracias a todos .
soy de benidorm por aqui cerca hay gente del club
________________________
saab 9000 aero
edusaab
Mensaje por edusaab »
Bienvenido......Pues mira esta web seguro que te va a gustar, especialmente dedicado al 9000 Aero.
http://webpages.charter.net/ralimi/aero/
otra web interesante..... www.saab9000.com y www.saabcentral.com
Engine Design
Type 4 cylinder, in-line
Arrangement Transverse, with dual counter-rotating balance shafts
Cylinder block Cast iron
Cylinder head Light alloy
Valve train Dble. overhead camshafts, 4 valves per cylinder
Displacement 140 cu. in. 2290 cc (2.3L)
Bore 3.54 in. (90 mm)
Stroke 3.54 in. (90 mm)
Fuel Requirement Unleaded 91-93 AON (Premium) (98 RON Europa)
Cooling System Water-cooled, thermostatically-controlled electric radiator fan
Engine Specifications
Aspiration Water-cooled turbocharger with APC charge pressure control, intercooler
Horsepower @ RPM 225 @ 5500
Max Torque @ RPM 258 @ 1950 (348NM)
Compression ratio 8.5:1
Engine Mgmt/Fuel Injection Saab Trionic
Electrical System
Ignition Saab Direct Ignition (DI)
Alternator 1070 W, 115A
Battery 12V, 62AH
Steering
Type Power-assisted, rack and pinion
Turning circle 35.8 ft. (10.9m) (curb to curb)
Turns (lock to lock) 3.2
Drive Train
Type Front-wheel drive
Transmission ratios: Manual Automatic
first 3.38:1 2.58:1
second 1.76:1 1.41:1
third 1.18:1 1.00:1
fourth 0.89:1 0.74:1
fifth 0.70:1 N/A
intermediate N/A 0.90:1
Final Drive 3.61:1 4.28:1
Chassis and Suspension
Front suspension Strengthed Macpherson struts, eccentrically mounted coil springs, low pressure gas-hydraulic shock absorbers, 19mm stabilizer bar.
Rear suspension Lightweight, beam-type axle, panhard rod, oil springs, low pressure gas-hydraulic shock absorbers, 19mm stabilizer bar.
Braking system Anti-lock braking system with 3 hydraulic circuits, ventilated discs front, solid discs rear, self-adjusting
Brake Discs Ventilated front diameter: 11.0 in. (278 mm). Rear diameter: 10.2 in. (256mm)
Parking Brake Mechanical, self-adjusting on rear wheel discs
Traction Control Saab TCS
Wheels 6 1/2 x 16 light alloy, 3-spoke with polished rims.
Tires 205/55 ZR 16
Interior
EPA size class Large car: 5-door = 123 cu. ft. (122 cu. ft. with sunroof)
Seating capacity 5
Trunk capacity 23.5 cu. ft.
Cargo capacity rear seat folded 56.5 cu. ft.
Dimensions
Wheelbase 105.2 in. (2672mm)
Front track 60.4 in. (1534mm)
Rear track 59.2 in. (1504mm)
Overall length 187.4 in. (4620mm)
Overall width 69.4 in. (1764mm)
Overall height 55.7 in. (1415mm)
Curb weight 3,210 lbs. (5 spd) 3,270 lbs. (automatic)
Fuel capacity 17.4 gallons (US)
Y la nuestra.
