Hola, a mi pregunta sobre el Gateway 500, me responden que no es compatible porque SAAB ha vuelto al cableado normal:
Hello, is there any news about compatibility with Gateway 500 and SAAB
> 93 Sport Hatch with infotaiment 150 ,
> car series MY 07.
> I will like to buy one of those but....
> Cheers.
Hi, the SAAB 9-3 MY2007 doesn'T use MOST anymore, they returned to copperwired devices.
It is not supported by Gateway500, and isn't supported by ice>Link Plus, may you can use ice>Link lite,
or lite AV ( lite AV is suggested if you have a Video capable iPod), which uses the AUX in of your radio,
charges the iPod. All controll (volume can be controlled via headunit) can be controlled via iPod.
If the radio doesn't has got an AUXin feature, then i can suggest only ice>Link FM / Ice>Link One
which uses the aerial of your car, ( connects directly into the ant connector of your car radio,)
and the ant., power ant. can be merged in. It can be received as the best radio station in the area
( it is not a wireless modulator.) EU certified solution.
Thank you for your patience.
If you have got any further questions, please contact us again..
Best regards:
Dension Technical Support Europe
http://www.dension.com
http://support.dension.com
Don't know where to buy? Find it on : http://www.dension.com/dealers.php
Compatibility Database : http://www.dension.com/oem.php
Novedades desde "Dension"
Pues si mal no me he enterado, la adaptacion completa del ipod que se podía hacer para los modelos anteriores al restiling (gateway 500, de unos 500 euros) sigue siendo la misma, pero para los modelos nuevos, como no traen cableado de fibra optica, se puede poner cualquier sitema más común. Hemos ganado en compatibilidad y hemos perdido en exclusividad.
