preguntales que si compras dos si te hacen descuento y lo pillamos a la vez aunque yo quiero el Stage 2 para el 1.8t 150cvs. sino llamando pero mi ingles.... le dire a mi novia en todo caso que lo encargue ella... si quieres agregame el msn o escribeme un correo y me cuentas, mafius1987@hotmail.comJoseRC escribió:Me han contestado de BSR UK y dicen:
"Good Morning Mr XXXXXX,
Thank you for your enquiry about a BSR PPC.
The PPC is supplied with highly developed and sophisticated tuning software from BSR. The software optimizes all engine parameters such as ignition point, fuel, boost pressure etc. The software is developed for each engine type and is tested carefully with the most advanced equipment available. This will guarantee the best performance, durability and fuel economy. BSR tuning software also complies with current emission requirements.
The power and performance is well documented and often “best in test”, which confirms that BSR leads the development of tuning software for newer car models and control systems.
At last you can get away from soldered chips, breaking up ECUs and mounting extra boxes and flexes in the engine bay. With PPC Tuning System you can tune your car without even lifting the hood. Just as simple as advanced!
“UNLIKE ANY OTHER REMAP AVAILABLE, YOU DON’T HAVE TO TAKE YOUR CAR TO BE SET UP ON A ROLLING ROAD, YOU CAN TUNE THE CAR FROM THE COMFORT OF YOUR OWN DRIVEWAY.”
You’ll see the benefits from tuning your car with BSR as soon as you turn the key, You’ll see from the graph below that more power is available earlier in the rev range, this means in most conditions you’ll be able to retain if not slightly improve fuel economy as you will not have to down shift as much to make use of the vehicle power.
The price for a BSR PPC is 648.80 Euros inc VAT and delivery to Spain.
Along with that you’ll also receive free internet updates for your vehicle when available.
If You have anymore questions please don’t hesitate to call us on 01932 338600
Happy to help"
Total que es 90 Euros más barato que la página sueca, pero no hay forma de comprarlo on-line. Que los llame...
Reprogramación de ECU
pincha en el banner que hay en la pagina de entrada al club , y saca la visaivandlf escribió:En Partsforsaabs ...
tony saab 9-3
Os ayudare con vuestro ingles. Os comento meter en google (traductor google) Y te saldra la paguina donde escribes en español lo que quieras decir, siempre escribiendo cosas que se pueda hacer una traduccion mas o menos literal pero a verdad que funciona bastante bien no como sifueramos bilingues, pero lo entienden.
Un suludo
Un suludo
De cojones te entienden, si..tony saab 9-3 escribió:Os ayudare con vuestro ingles. Os comento meter en google (traductor google) Y te saldra la paguina donde escribes en español lo que quieras decir, siempre escribiendo cosas que se pueda hacer una traduccion mas o menos literal pero a verdad que funciona bastante bien no como sifueramos bilingues, pero lo entienden.
Un suludo
Hace ya una semana que les he escrito. No saben...no contestanMarioSaab escribió:Yo te recomendaría que le mandases un e-mail a Partsforsaabs por si te podían conseguir la repro de BSR para un biopower, a lo mejor no lo han subido todavía a su página.
Quizás es por un problema de mi inglés-IndioMarioSaab escribió:Que raro... el cruce de emails que he tenido con PfS, han sido muy fluidos, en una o dos horas me han respondido![]()
Reenvíalo, por si acaso...
Tu tener BSR para mi saab biopower. Yo comprar.
tony saab 9-3
Si queréis hablo con ellos, tengo una relación fluida con los dos...Darme los detalles y les llamo esta tarde...
Por cierto, la comparación de las curvas de potencia, no las estaréis haciendo con lo que ellos ponen en su web, no? Porque no es más que información comercial, ni por asomo se parece a las curvas de un coche de verdad!!
Lo que no entiendo, porque no compráis directamente a BSR?
http://en.bsr.se/products/t1219/
