El reto
- alvar9000
tocayo, esta vez la has clavado
This is a great example of how language and faulty logic can quickly lead you astray. Sometimes you have to slow down and look carefully at what really happened. So, after doing this (for more time than you care to admit) and "Hmmming" a few more times, you finally get it and say "Ah! Well, Son, here's what happened. The customers each ended up paying $9 for a total of $27, that's true. They started out with $30, got $1 back each, so spent $27 in total. Of that $27, the hotel got $25, and the bellhop got $2. OK? Do you see that? It all adds up fine. You added the bellhop's $2 on top of the $27, which was where you made your mistake. All right?" Then you have an idea: "So, since I bailed you out here, you get to wash the dishes tonight instead of me!" And you walk into your study thinking "Wow, I've got to be more careful — that almost got me!"
Este es un ejemplo de como el lenguaje y la falsa logica pueden liarte. A veces tienes que frenar y revisar con cuidado. Cada cliente pago 9$ lo que suma 27$ eso es cierto. Empiezan con 30$ y le devuelven 1 asi que tienen 27$. De esos 27 el hotel se cobra 25 y el botones se queda 2$. Al final todo suma bien. Tu sumaste los 2$ del botones a los 27, ahi es donde cometiste el fallo.
Un saludote
Un saludote
si ya digo yo que tanta integral eliptica y tantas coordenadas hiperbolicas no sirven pa naaa
- alvar9000
rescatado del olvido vuelve:
In the Northern Hemisphere, why is the number of days from the Spring Equinox to the Fall Equinox three (3) days longer than the number of days from the Fall Equinox to the Spring Equinox?
en el hemisferio norte, por qué hay tres dias mas del equinocio de primavera al de otoño que del equinocio otoño al de primavera???
- alvar9000
se me habia pasado poner la respuesta
Is it because of those lazy, crazy days of summer? Is it because we set the clocks forward in spring? Is it because we simply forget to count when we're digging out from blizzards? No, no, and no. The answer is that the Earth's orbit is an ellipse. Kepler's second law states that a line connecting a planet to the sun sweeps out equal areas in equal times. In other words, the farther away from the sun a planet is in its elliptical orbit, the slower it orbits. The earth is closest to the sun in January and farthest from the sun in July. (Pretty weird, huh? We're warmest when further away, and coldest when closest to the sun. This points out the power of the tilt of the earth's axis and concomitant more direct sunlight we receive in the summer than in the winter.) This means the earth moves most quickly along its orbit in the months around January and most slowly in the months around July. Since rotation of the Earth is not influenced by distance from the sun, the slower moving earth sneaks in a few more days between the Spring and Fall Equinox in the Northern Hemisphere
es por esos dias tranquilos de verano? o porque avanzamos el reloj en primavera? o olvidamos contar durante las tormentas de nieve? No, la respuesta es que la orbita de la tierra es una elipse. La 2º ley de Kepler establece que la liena que une tierra y sol barre areas iguales en tiempos iguales, en otras palabras, cuanto mas lejos del sol más lento orbita. La tierra esta mas cerca del sol en enero y mas lejos en julio (raro, no? mas caliente cuando esta mas lejos. Esto demuestra el poder de la declinacion de la tierra y por el hecho que el sol incida mas perpendicularmente en verano) eso significa que la tierra se mueve mas rapido en los meses alrededor de enero y mas lento en los meses de julio. Como la rotacion de la tierra no esta influenciada por la distancia al sol, el movimiento mas lento de la tierra implica unos pocos dias mas entre el equinocio de primavera y de otoño en el hemisferio norte.
Un saabludo
Un saabludo
- alvar9000
venga otro mas:
Why is a bond with super glue so much stronger than regular glue? And do you know of some unexpected uses for the product?
por qué una union con superglue (loctite) es mucho mas fuerte que con pegamento normal? y conoces algun uso no habitual de este producto?
un saabludo
un saabludo
esta noche de Reyes pasada llegué tan calzado a casa que al ir a envolver los regalos y ver que no encontraba el papel de celo cojí el bote de superglue y ala!!!!Pegué los pliegues de los papeles de regalo con el super-pegamento. Sobra decir cómo quedaron los regalos envueltos, mis dedos, y que me gasté casi un bote del dichoso superglue.alvar9000 escribió:venga otro mas:
un saabludo
PD: El whisky+cocacola+superglue = nada bueno.
y pa este tb tengo respuesta...pq el bote de superglue cuesta 4 o 5 euros más que el pegamento normal...nos ha jodido si pega mejor!!!!alvar9000 escribió:venga otro mas:
un saabludo
- alvar9000
la respuesta
Super glue gets its bonding strength from its main ingredient, cyanoacrylate, an acrylic resin that cures (forms its strongest bond) almost instantly. The only trigger it requires is the hydroxyl ions in water – not a problem, because virtually any object you might wish to glue will have at least trace amounts of water on its surface. Super glue undergoes a process called anionic polymerization, in which the cyanoacrylate molecules link up when they come into contact with water. The molecules move in chains, forming a durable plastic mesh. As the glue thickens and hardens, eventually the molecular strands can no longer move, resulting in the super bond.
el superglu (loctite) obtiene su resistencia de su principal componente, cianocrilato, una resina acrilica que cura (forma uniones mas fuertes) casi instantaneamente. La unica necesidad son los iones de hidroxil del agua, (no es problema) ya que cualquier objeto que quieras pegar tiene al menos trazas de agua en su superficie. El loctite sufre un proceso de polimerizacion anionica, en la que las moleculas de cianoacrilato se unen cuando se ponen en contacto con el agua. Las moleculas forman cadenas, formando una celda plastica duradera.. Conforme se endurece el pegamento las moleculas no pueden moverse mas, generando la superunion.
Some unexpected uses of super glue are to close wounds instead of stitches and super-glue fuming to detect latent fingerprints. (The object being checked is placed in a heated, airtight container. Cyanoacrylate is added; as it evaporates and is circulated throughout the container, it reacts to materials that may have been left behind, making the fingerprints visible.)
Algunos usos no habituales del loctite son para cerrar heridas en lugar de tiritas y vaporizacion de loctite para detectar huellas dactilares latentes. El objeto a comprobar se coloca en un recipiente cerrado y calentado. se añade el cianocrilato, se evapora y circula por el recipiente, reacciona con el material haciendo visibles las huellas. Seguro que lo habeis visto en CSI
Un saludote
Un saludote
Así que el rollo ese de la urna es verdad y encima es con superglú.
Lo que inventan estos americanos.
Lo de las heridas lo he comprobado... accidentalmente... lo que no entiendo es si necesita de moléculas de agua para poder pegar... porqué pone que las superficies a unir han de estar secas.
Tampoco me convence como pegamento... en cuanto cristaliza se vuelve muy quebradizo, y s epega mejor donde no quieres que se pegue que en lo que quieres pegar...
- alvar9000
una cosa es que necesite agua para pegar y otra que las superficies esten encharcadas
por muy bien que seques las superficies siempre quedara la cantidad de agua necesaria (trazas de agua)
Cada pegamento tiene sus ventajas y sus inconvenientes, o mejor dicho, sus aplicaciones correctas. Eso del multiuso es como los SUV un buenoparanada (o como decia un profesor mio, pipa y lavativa, mala combinacion) la gran virtud del loctite (nombre comercial del cianoacrilato) es que pega muy rapido, no siempre en el sitio adecuado
Un saludote
Un saludote
