New SAAB member
Aquí se presentan los nuevos foristas.
lfteixeira
Re: New SAAB member
Mensaje por lfteixeira »
Cachi, i can't give a good advice, because i don't know what options you have for your radio.
But you have for a simple AUX-IN connection that you can use with any MP3 Player, but you don't have any control over the IPOD:
http://www.elkparts.com/saab-93-ss-m03- ... p2386.html
And for full integration you have:
http://www.dension.com/products.php?pageID=11
I don't know the price, but it ain't cheap. :D
lfteixeira
Re: New SAAB member
New upgrade:
Goodridge Brakelines (http://www.partsforsaabs.com/product_in ... ts_id=1388)
New oil in the brake system. (And clutch).
Now i have a completely different feeling in the brake pedal.
It takes a lot LESS force to brake hard.
Very nice, it worth it.
New map in the ECU, a stronger one, around 245bhp and 350Nm!!! Even with GPL, what a punch in the back!!! :twisted:
VR
Re: New SAAB member
Mensaje por VR »
Bienvenido al foro.
lfteixeira
Re: New SAAB member
Well, almost 1 year later it's time to update.
The car has some damages from 2 little road problems, but soon to be fixed.
Meanwhile, i installed a Aero rear spoiler and refurbished the wheels:
Tomorrow it's a big day for me, besides the usual 10000Km service (oil, filter, plugs, etc) it will receive:
- Mitsubishi TD04HL-15t (With a new core)
- Maptun Turbo Hoses
- Forge Dump Valve
- Maptun 3" Downpipe with race cat
- And of course a new map.
(Based on a Stage 1 for a B205R from Maptun, but adapted to my B205E) :D
From 150cv and 240Nm to 250cv and 370Nm... :D
I will try to get pictures from the operations to share here!
Wish me luck! :mrgreen:
Jotaele
Re: New SAAB member
Mensaje por Jotaele »
Cool! :8)
Saab 900 Sedan 2P T8. 1986
Socio nº248
Mintxo
Re: New SAAB member
Mensaje por Mintxo »
Nice car!!!
Buena suerte, Good luck!! :wink:
Saab 9000 Airflow MY90
Saab 900 S Turbo 16v MY92
Nº socio 262
lfteixeira
Re: New SAAB member
As fotos... :D
lfteixeira
Re: New SAAB member
After installing a new IC, a did a little more tweaking.
And running on LPG i was able to get 300bhp... :D
RPM: 6000
Airmass: 1100
Turbo pressure: 1,1 bar
Torque 350Nm
Power: 302bhp
I'm happy... :lol:
The new IC photos:
Side by Side
The old one:
The new one:
VR
Re: New SAAB member
Mensaje por VR »
May be Serxio is not so happy, as you are getting closer to his performance...lol
smap
Re: New SAAB member
Mensaje por smap »
VR escribió:May be Serxio is not so happy, as you are getting closer to his performance...lol
lol ...
I really don't care ... but just to be on the safe side I'm putting a B234R engine together with a FM57101 gearbox on my 9000 :wink:
The engine will have a TD04HL-19T instead of a 15T ...
lfteixeira
Re: New SAAB member
Just an update, i don't have much to tell.
I installed a Innovate LC-1 Wideband lambda probe to control the AFR.
I didn't need a gauge, because i connected directly to the ECU and i can monitor the AFR from the SID.
I also had to lower the power output, the LPG systems was having problems dealing with all the power.
Now it's time to replace the tyres.
Will use 225/45 R17 (instead 215/45), i didn't decided yet what make and model should i use. (I'm using Goodyear Eagle F1 Assymetric)
And now i have another addiction... (See photo)
Apenas uma actualização, não tenho muito para contar.
Instalei uma sonda Inovatte LC-1 Wideband para controlar melhor a AFR do motor.
Não precisei de instalar um manometro porque liguei directamente a sonda á ECU e consigo monitorizar a AFR no SID.
Tambem baixei a potencia do carro, porque o sistema de GPL estava com problema em lidar com tantos cavalos.
Agora é tempo de trocar de pneus.
Agora vou usar 225/45 inves dos 215/45 originais. Ainda não decidi a marca e modelo que devo usar. (agora tenho Goodyear Eagle F1 Assimetricos)
E agora tenho outro vicio... (ver foto)
Suzuki Vitara (1.9 TD)
Sputnik
Re: New SAAB member
Mensaje por Sputnik »
awesome ! :wink:
lfteixeira
Re: New SAAB member
Aquí es una actualización de mi SAAB.
Sigue trabajando bien, pero es el momento de hacer algunos cambios.
Esta vez tiene 241.000 kilometros y es en el mecánico:
  - Cambiar el motor para b235 (a Viggen)
  - Nuevo kit de distribución, PCV y el cárter de limpieza
  - Instale el embrague Viggen
  - Instalación de un Cambio a corto
También llevó a la revisión:
  - Vuelva a colocar el filtro de aire (motor y cabina)
  - Pastillas de freno (delantero y trasero)
Sin embargo, a principios de este año también tiene un sistema de escape completo con 3 ". Un ruido hermoso, pero sin el viaje que regaña.
Pero por ahora no han decidido si o no cambiar la caja de cambios para el Viggen.
Si tengo la caja de velocidades actuales que es más corta y me sale el coche más rápido.
O cambio por la caja de cambios Viggen es más largo, más lento, pero más económico.
Lo que usted dice?
PS: Traducción de Google.
